Reporting the timing of reg to reg paths in Cadence RTL Compiler
biju4u90
Full Member level 3
Full Member level 3
Is there any command in Cadence RTL Compiler that will report the reg to reg timing paths only? I see commands to report maximum number of min slack paths or commands to report timing from a starting point to end point. But I don't see any commands for categorizing the paths like r2r paths or input to register or register to output paths!
Can anyone please help?
rca
Advanced Member level 5
Marin
you could create a cost_group reg2reg.
or
report_timing -from [all_registers] -to [all_registers], it will reports the worst path from / to registers.
biju4u90
Full Member level 3
Full Member level 3
That works @rca
Thank you.. :)
