[SOLVED] replacing AT 89 C4051 with AT 89 S4051
sandu paul
Newbie level 3
Romania
Hello!
I'm thinking at replacing an AT89 C4051 with an AT89 S4051, if possible. Any advice will be apreciated.
I have an x.hex file to write into an AT89C4051, but the simplest programmer from BlowIt doesn't work, so I wonder if it is possible to write the very same x.hex program into an AT89S4051, using ICSP, because of the simpler programmer needed in this case.
