blueroomelectronics said:It's generally poor design to use a low I/O micro and a lot of expensive glue logic when a micro with more I/O would eliminate the glue logic.
To run 4 seven segment displays takes only 11 I/O pins and 4 transistors so why not use a bigger micro?
If you are really cramped for I/O you could also do it with a CD4511 and 4 transistors 8 I/O pins.
Cricket Thermostat prototype
I'm sure you meant to qualify that statement with; "In my opinion...", correct?blueroomelectronics said:It's generally poor design to use a low I/O micro and a lot of expensive glue logic when a micro with more I/O would eliminate the glue logic.
blueroomelectronics said:Ok, In my opinion. But that said I am using a 74HCT595 as an I/O expander in my next kitI'm using a 40pin DIP and don't want to switch to TQFP.
pasicr said:
pasicr said:Hi Aurbo,
here is,
regards
p.s. Where are you from?
can you easy buy tpic6b595n,
It is generally a bad idea to make general statementsblueroomelectronics said:It's generally poor design to use a low I/O micro and a lot of expensive glue logic when a micro with more I/O would eliminate the glue logic.
