remote controlled light dimmer
usernam
Full Member level 5
www.electroda.pl/eboard/download2.php.com
hi
i'm building a remote controlled light dimmer circuit.i've got to dim two lights.i'm using a phillips remote which uses the RC5 protocol. I've decoded the code from the remote but i now have to use a triac and control the intensity of the light. i'll be using a microcontroller for this. i need the microcontroler program for this. i'd prefer it if the prog was for a atmel 89c51 or an atmel 89c2051 but any other program is fine too.
thnx in advance
microcontroller light dimmer
This link might be useful for you:
and this one too:
Regards
:D :D :D
elektor 2003 dimmer
thnx.
the first site doesnt seem to be working but the second link was really helpful. do u know any site where i can get a little more information on the zerocrossing detection circuit and also is it possible to get a zerocross detection circuit in IC form.
light dimmer using atmel
Another useful link for you could be this one:
Bye
:D :D :D
remot controlled light dimmer circuits
thnx man.
really helpful. got it worked out now. :D
just have to implement it now. :?
Hi usernam,
You can also try Elektor Electronics, No. 323-July/August 2003 UK issue includes:
Remote Light Control with Dimmer:
The microcontroller-driven switch described in this article allows one lamp to switched on and off as well as dimmed, all using an RC5-compatible infrared remote control.
Maybe that's all you need...
If you'd like a copy of this article for learning and evaluation porposes, PM me and I'll upload it here.
Regards.
+elektor +issue 323, july 2003
Hi JR, I would like to see the article because I am having some problems with a project very much like this....
Is it possible that you could e-mail me the article og upload it elsewhere...?
Hope you can help me..
remote control to control lamp dimmer circuit
MODERATOR ACTION: attachment delete as in same topic orignal pdf file posted so why not safe some space here
Hi Woodster, usernam,
Sorry for my late reply,
I've scanned the article and I'm uploading the three pages below.
I hope it helps.
Good Luck!
__JR__
light dimmer ic
hi jr, woodster
thnx for the article but its a bit late. i already finished the dimmer. :)
here's a little write up on it if anybody is interested. It only covers the hardware portion and not the software part. unfortunately no time to write about the software. hopefully i'll get some time soon.
atmega light dimmer
sir ,
i am from MIT Manipal, working on the same project(Light dimming using RC5 remote)... i downloaded your article which has the harware description but please send me the software code at the given email id as i need it very urgently...
Please spend your precious few minutes for us..
Thanks in advance eagerly waiting for your help...
Thanking You,
Rohit Agrawal
Email : rohitagra@gmail.com
remote operated dimmer light circuit
thank you
Re: light dimmer ic
hi guys i need help in designing an IR remote control to switch on/off and vary the illumation level of an incandesent lamp with the following
1.able to operate from a distance not more than 10m
2.able to switch on at minimum luminous intensity level when power on switch is pressed
3.able to vary the illumination level in at least four preset levels by pressing intensity control switches
4.the operation should not interfer elecromagneticradiation that cause disturbances in other eletronic devices like radios
Re: microcontroller light dimmer
Hi hugo,
I need your project detail, n may be your links are outdated.
Kindly update these links.
regards
waqas ahmed
Re: light dimmer ic
hi jr, woodster
hey i have done the circuitary and finding difficulty in reading the data from remote control.what is the logic to read the square pulses. i am also using philips remote.RC5 protocol.
hi can you please send me the code and circuit for light dimming
