Relay two ways using fet
Al-Daloo
Newbie level 6
Hi, I have two voltage one of them +ve and the another is -ve, i like to switch between them, if we have input "1" the output is the +ve voltage and if input "0" the output should be the -ve voltage. i'm working in 90nm technology. i tried to use two transistor but there is amount of voltage clipped (from + and - ve ).
thanks in advance
sounds like a job for a changeover relay.
Or do something similar with transistors.
i have dead-end, the solution by using two inverters>
