A.Anand Srinivasan said:k... you simulate things by connecting pin2 of the optocoupler to the ground and giving 5V(as if the computer gives) to pin1 and watch if the relay switches.... now remove that 5V and see if the relay switches... if it does then things are fine... if it doesn't switch back then there is something wrong with the optocoupler...
