ben8118
Junior Member level 1
- Joined
- Feb 12, 2010
- Messages
- 19
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Kuala Lumpur
- Activity points
- 1,419
I presume that the relay itself is stuck to on-state, not the controlling circuit? In other words, it remains "on", even after removing the power supply. Your post isn't very clear in this regard.Would like to ask would it be the inrush current from the fluorescent lamp cause the relay jam on the 'on' stage or others problem cause it.
Which are these two relays?when I use the relay from the design it work fine. However when I use other relay it have problem.
Would like to ask would it be the inrush current from the fluorescent lamp cause the relay jam on the 'on' stage or others problem cause it/
Thanks.
ALERTLINKS:cameo_2007: Do you have any idea how to measure the current from the fluorescent lamp?
Thanks.
