kushal nandanwar
Full Member level 3
Can I drive 12V coil relay with 24V power supply
Note: This feature currently requires accessing the site using the built-in Safari browser.
You could add a resistor that has the same value as the relay coil resistance then the relay will work properly but the resistor will waste power by getting hot.
