BlackHelicopter
Full Member level 2
Hi I'm driving a relay using a FET using the circuit shown. And parts keep blowing up. What kind of transient effects are likely to occur here and what can be done about it? Also, I see a lot of BJT circuits with a reverse diode in parallel with them when driving relays (diode is connected between Collect and Emitter) what does that diode do exactly and why is it there? Do I need one at the output of the comparator? (open collector?)
Thank you!
Thank you!
