Register Log in
Relative sensitivity of various electronics components to ESD damage?
treez
Advanced Member level 5
cambridge
Which ones of the following electronic components are more sensitive to ESD damage than the others.? Can you rate these in order of most ESD sensitivity?
1…DCM3623T50M53C2T00 DCDC module (ESD page 15)
http://www.vicorpower.com/documents/datasheets/DCM3623x50M53C2yzz_ds.pdf
2….Infineon TO220 NFET (IPP023N10N5)
https://www.infineon.com/dgdl/Infin...n.pdf?fileId=5546d461454603990145d5a675f86494
3….MCP6002 opamps (SOIC8)
http://ww1.microchip.com/downloads/...1U-2-4-1-MHz-Low-Power-Op-Amp-DS20001733L.pdf
4….ACS722 Hall sensor current monitor IC
https://www.digikey.co.uk/product-d...tems/ACS722LLCTR-05AB-T/620-1634-2-ND/4915375
5….BC846 BJT
https://www.onsemi.com/pub/Collateral/BC846ALT1-D.PDF
FvM
Super Moderator
Staff member
Bochum, Germany
Expect that manufacturers give specification, either in datasheet or general product documentation. Most of the mentioned devices have such a specification, I presume you noticed it. According to it, the MOSFET has highest ESD level (8 kV HBM), the DC/DC lowest (Jedec class 1C = 1-2 kV HBM).
But the spec doesn't necessarily tell which device is most sensitive, there may be also issues not covered by the ESD spec, e.g. ESD triggered latchup in powered state.
Reactions: treez
    treez
Toggle Sidebar
Design Fast
