Regarding synthesizable DELAY concept...
rakesh_aadhimoolam
Full Member level 4
hello.......
can we be able to make a synthesisable delay model.....
i mean""""given a 1MHz signal it has to be outputted after a 1 ms delay and there shoold be vhdl code for it which is synthesizable""""""
spauls
Advanced Member level 2
No,
Synthesis tool will ignore all kinds of DELAYS
steven852
yes, synthesis tools will ignore all delay lines except you use "dont_touch" command.
bansalr
Full Member level 3
The abstract way of delaying may be used with delayingw.r.t clock timing.
i.e. introduce FLIP FLOP or use a RAM to delay if it is a mulitple of clock pulse width.
vipulsinha
Member level 2
Yes you can do that but the synthesis tool Just ignores the AFTER clause if you are using. The best way to do is to make a counter and output the design output after specific counter count that satisfies your delay
vipul
