struct menu year_function(struct menu Initialsetup)
unsigned int value_read3;
int keyvalue;
unsigned char eeprom_value = 0;
unsigned char status=0;
if(Initialsetup.language == 0)
Initialsetup.ChoiceOfLanguage = 0;
else
Initialsetup.ChoiceOfLanguage = Initialsetup.language;
lcdClear();
Initialsetup.Current_mode = Third_mode_year;
Initialsetup.value_store = 2000+year;
AT25160B_init();
while(1)
keyvalue = keyboard_get_key_state();
if(keyvalue == UP)
if(Initialsetup.Current_mode == Third_mode_year)
Initialsetup.value_store++;
if(Initialsetup.value_store >= 2040) Initialsetup.value_store = 2014;
if(keyvalue == DOWN)
Initialsetup.value_store--;
if(Initialsetup.value_store <= 2014) Initialsetup.value_store = 2030;
if((keyvalue==ENTER)&&(status == 0))
delay_ms(100);
Initialsetup.datetime[0] = Initialsetup.value_store;
Initialsetup.datetime[0] = Initialsetup.datetime[0] % 100;
year = Initialsetup.datetime[0];
spi_eeprom_Write(0x000f, &year, sizeof(year));
value_read3 = spi_eeprom_Read(0x000f);
lcdClear();
lcdMoveCursor(1,5);
print_integer(value_read3);
delay_s(3);
Initialsetup.Current_mode = Fourth_mode_month;
status = 1;
return Initialsetup;
if((keyvalue == ESC)&&(status == 0))
Initialsetup_DisplayChange_strings(Initialsetup);
Initialsetup = country_menu_function(Initialsetup);
if(Initialsetup.value_store == -1)
Initialsetup = year_function(Initialsetup);
status = 1;
if((keyvalue == NEXT)&&(status == 0))
status = 1;
if((keyvalue == ZERO)&&(status == 1))
status = 0;
Initialsetup_Display_string(Initialsetup);
void spi_eeprom_Write(uint16_t memAddr, uint16_t data[],uint16_t len)
delay_ms(2);
spi_eeprom_Write_Enable();
spi_selectChip(AT25160B_SPI,AT25160B_SPI_NPCS);
uint16_t packet[3]={EEPROM_DATA_WRITE,memAddr>>16,memAddr&0xFFFF};
spi_write_packet(AT25160B_SPI,packet,3);
spi_write_packet(AT25160B_SPI,data,len);
spi_unselectChip(AT25160B_SPI,AT25160B_SPI_NPCS);
delay_ms(100);
return;
memAddr>>16
void spi_eeprom_Write(uint16_t memAddr, uint8_t data[],uint8_t len)
delay_ms(2);
uint8_t packet[3]={EEPROM_DATA_WRITE,memAddr>>8,memAddr&0x00FF};
delay_ms(100);
return;
status_code_t spi_read_packet(volatile avr32_spi_t *spi,
uint8_t *data, size_t len)
unsigned int timeout = SPI_TIMEOUT;
uint8_t val;
size_t i=0;
while(len) {
while (!spi_is_tx_ready(spi)) {
if (!timeout--) {
return ERR_TIMEOUT;
spi_write_single(spi,CONFIG_SPI_MASTER_DUMMY);
while (!spi_is_rx_ready(spi)) {
if (!timeout--) {
return ERR_TIMEOUT;
spi_read_single(spi,&val);
data[i] = val;
i++;
len--;
return STATUS_OK;
status_code_t spi_write_packet(volatile avr32_spi_t *spi, const uint8_t *data,
size_t len)
size_t i=0;
uint8_t val;
while(len) {
if (!timeout--) {
return ERR_TIMEOUT;
val = data[i];
spi_write_single(spi,val);
i++;
len--;
return STATUS_OK;
* EEPROM.c
* Created: 2/7/2015 4:39:16 PM
#include <avr32/io.h>
#include "EEPROM.h"
#include "spi.h"
#include "gpio.h"
#include "spi_master.h"
#include "lcd_display.h"
#include "delay.h"
uint8_t readdata;
struct spi_device SPI_DEVICE_EXAMPLE = {
//! Board specific select id
.id = AT25160B_SPI_NPCS
void spi_eeprom_Write_Enable(void)
spi_write(AT25160B_SPI,EEPROM_WREN);// send command
void spi_eeprom_Write_Disable(void)
spi_write(AT25160B_SPI,EEPROM_WRDI);// send command
void AT25160B_init(void)
//gpio of spi configuration
static const gpio_map_t AT25160B_SPI_GPIO_MAP =
{AT25160B_SPI_SCK_PIN , AT25160B_SPI_SCK_FUNCTION }, // SPI Clock.
{AT25160B_SPI_MISO_PIN , AT25160B_SPI_MISO_FUNCTION}, // MISO.
{AT25160B_SPI_MOSI_PIN , AT25160B_SPI_MOSI_FUNCTION}, // MOSI.
{AT25160B_SPI_NPCS0_PIN , AT25160B_SPI_NPCS0_FUNCTION} // Chip Select NPCS.
gpio_enable_module(AT25160B_SPI_GPIO_MAP,sizeof(AT25160B_SPI_GPIO_MAP) / sizeof(AT25160B_SPI_GPIO_MAP[0]));
gpio_enable_gpio_pin(AT25160B_SPI_HOLD);
gpio_set_gpio_pin(AT25160B_SPI_HOLD);
spi_master_init(AT25160B_SPI);
spi_master_setup_device(AT25160B_SPI,&SPI_DEVICE_EXAMPLE, SPI_MODE_0,AT25160B_SPI_BAUDRATE, 0);
spi_enable(AT25160B_SPI);
uint8_t spi_eeprom_Read(uint16_t memAddr)
uint8_t packet[3]={EEPROM_DATA_READ,memAddr>>8,memAddr&0x00FF};
spi_read_packet(AT25160B_SPI,&readdata,1);// read contents of memory address
delay_ms(100);
return readdata;// return data
delay_ms(2);
delay_ms(100);
return;
delay_ms(2);
delay_ms(100);
return;
delay_ms(2);
delay_ms(100);
return;
size_t len)
size_t i=0;
uint8_t val;
while(len) {
if (!timeout--) {
return ERR_TIMEOUT;
val = data[i];
i++;
len--;
return STATUS_OK;
