Regarding PLL frequency synthesizer application
bestluck
Newbie level 1
I m currently doing an assignment regarding PLL(phase locked-loop). I would like to ask whether is there any way to use THE FREQUENCY to control the turning direction of the MOTOR. Or is there any way to make use of the frequency as CONTROLLER to control the motor. I would like to use this to design an autogate, a small size one. Just for demo purpose. Thanks very much!
chuckey
Advanced Member level 5
Southampton and holiday cottage in Wensleydale (UK
If you use a synchronous AC motor this will "lock" to the frequency. The only way to reverse a motor is to switch over two phases.
VFDs (variable frequency drives) are three phase electronic generators that can output serious power (100 - 100KW) too drive mains motors. they normally can be adjusted 6Hz - 600Hz, giving motor speeds of .1 - 10 X rated motor speed.
Frank
mrarslanahmed
Full Member level 2
gujranwala pakistan
yes there is frequency based control for the AC motor......
there are programmable frequency to current convertors ....
mostly used in tachometers....
