aasai
Newbie level 5
Hi ,
In simple Asynchronous fifo , writing using clk1 & reading using clk2 , now i m trying to implement the Full & Empty Status flag for that i
==> Set the Direction Signal to High when Write_address( or Write_pointer ) is less than Read_address( or Read_pointer ) &&
i.e. ( Write_pointer > Read_pointer ) then Direction = 1;
Reset the Direction Signal to Low when Write_address( or Write_pointer ) is greater than Read_address( or Read_pointer )
i.e. ( Write_pointer < Read_pointer ) then Direction = 0;
Case 1: ( Full Flag )
I assert status Full flag When Direction Signal is Set to High && ( Write_pointer == Read_pointer ).,
i.e. ( Direction == 1 && ( Write_pointer == Read_pointer ) ) then Full = 1;
if not i deassert status Full flag to Zero (Low).
Case 2: ( Empty Flag )
I assert status Empty flag When Direction Signal is Set to Low && ( Write_pointer == Read_pointer ).,
i.e. ( Direction == 0 && ( Write_pointer == Read_pointer ) ) then Empty = 1;
if not i deassert status Empty flag to Zero (Low).
Here I have Problem when Comparing Write_pointer && Read_pointer to assert Empty or Full
i.e. ( Write_pointer == Read_pointer )
because here the two Pointers are from Two differernt clk domains so i need to do double synchronization for anyone of the Pointer for synchronization with respect to the other clk domain .
During Comparision of Pointers now i can compare only Write_pointer with two clk delay Read_pointer because of Double synchronization of Read_pointer.
i.e. ( Write_pointer == two_clk_delay_Read_pointer )
if i compare like above equation means i am having the problem of missing the exact ( Write_pointer == Read_pointer ) condition ..........
but i want to compare the exact ( Write_pointer == Read_pointer ) .
So Plz givre me solutions regarding or if you are following any buffer mangement techniques kindly discuss.
thank you for your time.
