Regarding 2 wire RS485 to microcontroller RX pin.
kiranhatti
Newbie level 6
Dear All,
I have designed circuit to convert 2 wire RS485 to TTL (to microcontroller RX pin).
Note: I am going to implement only Reception. So there is only one Max485 ic.
Can you please let me know whether the microcontrller will receive the data?
Please find the attachment.
  • RDU_RS485.pdf
The circuit is basically correct. Naming of the RS485 lines may be different, you have to check if "Rx+" and "Rx-" is connected correctly. "Rx+" should be more positive in idle state.
Thank u for your kind response.
Rx+ should be more positive in idle state means Rx+ should be pull down to ground right?
