That depends what kinds of application you are looking for. If you only want to get a precise reference, BandGap circuit could be a good choice. You can find alot of example circuit in the analog design textbook. If you want that reference has strong driving capability, you probably need a output buffer.
Well it depends on what you need the 2v for, ie., does it need to have a drive capability to power other circuits , or is it needed as a reference.
If you need a stable reference , bandgap is the best bet. Even in 1.6u technology, this should not be too difficult to implemet.
However if you need thid voltage to power some other circuitry running at 2V , the you need a LDO regulator. Being 2v in a 3v supply, with high Vt(I assume) you will have to use a PMOS driver in the final stage instead of the conventional source follower.Though this will have a higher output resistance you can compensate it with a cap.
if u only use 2v as a reference, u can design a circuit to get a bandgap voltage about 1.2v then use negative to boost the voltage to 2v. maybe like this
But the resistance has temperature-dependence , the bandgap vref hasn't temperature-dependence. So the output of upside plot will have temperature-dependence.
