Navaneeth.A.Gowda
I have recorded EEG data using openBCI which is in the range of -15000 to 15000 micro volts. I want to reduce this to the range of -100 to 100 micro volts. How do I do it?
I see no good reason to do that, but you could use a resistive divider.I have recorded EEG data using openBCI which is in the range of -15000 to 15000 micro volts. I want to reduce this to the range of -100 to 100 micro volts. How do I do it?
