Reducing via drill hole on OrCAD Layout
cerilet
Valencia
Hi everyone,
I am trying to print a board which has 0.2mm via drill holes, but when I print the top and bottom with the selection box Keep drill holes open checked the drills are bigger (0.8mm aprox.). I can not print them less than this value.
How can I fix it?
I am using OrCAD 16.2.0.
Thanks so much.
PCB design
Member level 4
Muscat, Oman
Check the padstack spreadsheet for the correct drill details!
The normal via drill given is 0.5mm and above!
cerilet
Valencia
Yes I did it in that way but doesn't works. I select the VIA1 and change the drill but nothing. I think is something wrong with the printing.
When I used OrCAD Layout 9 it worked, but with newer versions not.
Thanks for answering!
PCB design
Member level 4
Muscat, Oman
Check if there are more than 1 via type in the layout.
Right click on via - change via
cerilet
Valencia
In my design via1 is only used. All others are undefined (all set to zero).
electronicus
Full Member level 4
Romania
Click the "View Spreadshheet" button and select "Padstaks'. Edit the via comform design.
Good look.
cerilet
Valencia
I did it in this way. I think OrCAD has a programming error.
I tried all possible solutions but nothing.
