Register Log in
Reducing RAM & ROM consumption in coding
Mithun_K_Das
Advanced Member level 3
Dhaka, Bangladesh, Bangladesh
How can I rewrite this code to use less RAM & ROM?
ADC: 10bit. Speed: 1MSPS.
Data input range: 0-5V.
CPU: DSPIC30F2010; 16bit.
This code is working fine. But consuming 25% of total ROM & 40% RAM. I need suggestion to rewrite this code so that I can save some RAM & ROM.
I need at-least 20 samples to get the best result. Signal is both AC & DC. Other programs running in interrupt of 64uS which takes around 16us to complete.
//sensing
unsigned int input_voltage_sample[21];
unsigned int output_voltage_sample[21];
unsigned int battery_voltage_sample[21];
unsigned int ampere_sample[21];
unsigned data int input_voltage_sample_old=0;
unsigned data int in_avg_value=0,in_raw_value=0;
unsigned data int out_avg_value=0,out_raw_value=0;
unsigned data int curr_avg_value=0,curr_raw_value=0;
unsigned data int in_temp=0,in_max=0,out_temp=0,out_max=0,curr_temp=0,curr_max=0;
unsigned data int batt_avg_val=0;
int sample_step_cnt=0;
int adc_sample_cnt=0;
void input_fault_check()
   if(input_voltage_sample[sample_step_cnt]<(input_voltage_sample_old-10) || input_voltage<170)input_down_bit=1;
   else
      if(input_voltage>170) input_down_bit=0;
   input_voltage_sample_old=input_voltage_sample[sample_step_cnt];
void read_adcs(void)
  input_voltage_sample[sample_step_cnt] = ADC1_Get_Sample(2);
  output_voltage_sample[sample_step_cnt] = ADC1_Get_Sample(3);
  battery_voltage_sample[sample_step_cnt] = ADC1_Get_Sample(0);
  ampere_sample[sample_step_cnt] = ADC1_Get_Sample(4);
  input_fault_check();
  sample_step_cnt++;
  if(sample_step_cnt>20)
     sample_step_cnt=0;
     //extract input voltage
     in_temp=0;
     in_max=0;
     out_temp=0;
     out_max=0;
     curr_temp=0;
     curr_max=0;
     batt_avg_val=0;
     ac_calibration = EEPROM_Read(address1);
     output_calibration = EEPROM_Read(address3);
     amp_calibration = EEPROM_Read(address5);
     for(k=0;k<10;k++)
       //input max finding
       if(in_temp=input_voltage_sample[k],in_temp>in_max)
          in_max = in_temp;
       //output max finding
       if(out_temp=output_voltage_sample[k],out_temp>out_max)
          out_max = out_temp;
       //current max finding
       if(curr_temp=ampere_sample[k],curr_temp>curr_max)
          curr_max = curr_temp;
       //battery avg finding
       bat_calibration = EEPROM_Read(address2);
       batt_avg_val+= battery_voltage_sample[k]*(0.3+bat_calibration*0.005);;
     in_avg_value+=(in_max-270)*(0.62+ac_calibration*0.01);
     out_avg_value+=(out_max-270)*(0.62+output_calibration*0.01);
     curr_avg_value+=(curr_max-270)*(0.62+amp_calibration*0.01);
     //calculate battery
     battery=batt_avg_val/20;
     bat_read_ok=1;
     adc_sample_cnt++;
     if(adc_sample_cnt>5)
        adc_sample_cnt=0;
        input_voltage=in_avg_value/5;
        input_voltage_read_ok=1;//read bit set
        in_avg_value=0;
        if(input_voltage<100)input_voltage=0;
        if(input_voltage>170 && input_voltage<250)mains_status=1; //mains detection level
        else mains_status=0;
        output_voltage = out_avg_value/5;
        feedback_voltage_read_ok=1;
        out_avg_value=0;
        current = curr_avg_value/5;
        curr_avg_value=0;
        current_read_ok=1;
Thanks in advance.
FvM
Super Moderator
Staff member
Bochum, Germany
You have implemented float math for a few calculations that can also use integer math. Dropping the float library will save a lot of ROM, unless you need it otherwhere. dsPIC30F2010 has little RAM (only 512 bytes), if you want more data storage, you'll refer to a different chip.
Mithun_K_Das
That means if I write 62/100 instead of 0.62 (if use integer math) it will consume less ROM&RAM. Yes! I changed it and it saved a lot of RAM & ROM.
FvM
Super Moderator
Staff member
Bochum, Germany
Of course you need to take care of the number range. Under circumstances, the multiplicand must be casted to long before multiplying with 62.
Toggle Sidebar
