Redesigning PCB for ProPic 2 Gold
top2006 pcb
One question on ProPic 2 and IC-Prog
does they support 16F627A/628A 'A' versions?
As far as I know, you need to pull PGM pin to GND (according to IC-Prog page), does ProPic 2 has that features?
propic2 gold v2.0
I have read lots about the failure of PropicXP Gold. How it works with standard PCB (without 12C508) but with Gold software? Should I try the older Propic or try this new PropicXP... but I have to program 16F876A!!!
I have also read about the success of ICprog with Propic hardware... hows that?
Which version of ICprog should I download to program 16F876A?
12c508 do propic 2
thanks :D
clone picpro
propic2 .hex
I opened this Eagle Files and there is two missing connections, comparing the Eagle schematic with the original one:
1. Connection between Data signal and ZIF socket pin 15.
2. Connection between Clock signal and ZIF socket pin 16.
Why this version doesn't have those connections? Is it a mistake or is there some reason for that?
schema propic
Hmmm... very interesting. I build a copy of original propic2, but not have hex for vdd control, a long time I search for this, finally I found in this forum. Thank's!
pro pic gold 2.9
Hello All
Please I have a question regarding the potentiometer. It's written that it's adjusted for a 5volt output at the second opamp. Under what conditions should I adjust it?
i.e, when I just connect the power supply to the circuit or simulate programming (write a hex file to the parallel port without an MCU)?
Thanks in advance
propic2gold
this programmer is crap
drop kick your efforts
invest in a picall or a chinese top2006 usb or serial
the picall you can get for less than 150 euros
and the top for 70euros
the top covers 56000 devices
the picall a mear 700 or less
the propic a simple few
get a top and its sent direct for maybe some small tax also in your country
https://www.mcumall.com/forum/forum.asp?FORUM_ID=2
some stuff and links
propic gold
tray this it is ok.
parts:
. Печатна платка 0231 - 1 бр.
2. U1, U3 78L05 - 2 бр.
3. U2 7407 (ЛП9) - 1 бр.
4. VT1÷VT5 2T3308C - 5 бр.
5. VD1 zener (6.2÷7.5)V - 1 бр.
6. VD2 zener 8.2V - 1 бр.
7. VD3 green- 1 бр.
8. VD4, VD8 red ф3 - 2 бр.
9. VD5÷VD7 1N4148 - 3 бр.
10. C1, C3, C4 100nF - 3 бр.
11. C2 100µF/25,35V - 1 бр.
12. C5 (47÷150)nF - 1 бр.
13. R1 2.2kΩ - 1 бр.
14. R2, R7, R14, R17 (20÷33)kΩ - 4 бр.
15. R3, R6, R11÷R13 4.7kΩ - 5 бр.
16. R4, R5 560Ω÷1kΩ - 2 бр.
17. R8, R9, R15, R16, R18, R19 10kΩ - 6 бр.
18. R10 (2÷4.7)kΩ - 1 бр.
19. К1 - 1 бр.
from here:https://hobby.neomontana-bg.com/
in BG
and here is more:https://www.constructor.bg/mk/Programator.htm
pic12c508p pic12c508a difference
THE PCB FOR THE DOUBLE SIDED BOARD HAS IT BEEN MIRRORED OR I HAVE TO MIRROR THE TOP BEFORE PRINTING, SO THAT I CAN GET A GOOD ALINGMENT?
db-25 pcb
Here's a propic2 programmer db25 download attachment. but I need a db9 propic2 programmer can some share a pcb layout of the propic2?
thanks
best regards,
glenndr_15
