Emanuel Ricardo
Hi
I am doing simulations for a rectangular waveguide bend using HFSS 15, in the band 20-100 GHz. In these frequencies, several modes can be created, when TE01 mode, the input,goes through the bend. I am using HFSS for the first time and i cannot find anything about my question:
I have the bend geometry and 2 waveports, one in the begining of the bend and one in the end. The boundary of the bend is made with copper. Te01 mode (the second mode of the rectangle) is introduced in one waveport using "edit sources", choosing only the mode i want, (am i do it right?). Here is the circular bend:
Because new modes can appear due the bend, when i will define the waveport do i need to insert the maximum number of modes ? (25). Or, because I just want to see what TE01 power i have in the exit of the bend and i dont want to know how this power was lost, i just need to define 2 modes in each waveport? (have to define 2 because TE01 is the second)
In another way, the number of modes that i define in the waveports have influence in the field solution inside the bend?
Thank you
Thank you
