Rectangular versus dipole patch antenna array
kiwi_fabregas
Newbie level 6
Malaysia
antenna array dipole
I have an assignments on designing rectangular patch antenna at 5.8Ghz.First question is I have to compare my results on simulation between single element antenna with 2 elements array which i have already solve.The second thing is..my supervisor needed more details on the results which i think the best way is to compare the rectangular patch(my design) with the dipole.So,if any of you guys have done dipole array at 5.8Ghz..please share the details..really appreciate..
comparison rectangular patch antenna
what are your specifications of the array.kindly do let me know i can set up a couple of simualtions for you and you can compare the results yourself.
regards
sajid mohammed.
rectangular array patch antenna
dipole microstrip...5.8Ghz operating frequency...50ohm input impedance.....4.7 dielectric subtrate with 1.6mm thick...use copper as the conductor with 0.035mm thick....hee
