Hello, I've been working on a small NMR system using a single coil for transmit and receive at frequencies near 10MHz. I'm now trying to optimize the system so I can switch between transmit and receive faster. I have been using a combination of PIN diode SPDT switch circuits, PIN diode SPST switches, and IC analog switches. I want 70dB isolation from the transmit to receive port when in transmit mode, so I've been using two stages. The PIN diode circuits are nice in that they can give the lowest loss (like -0.2dB per stage) on the receive side, and thus the better overall noise figure, but integrated analog switches seem to give better recovery time. Here's an example of the PIN diode switch I'm working with at the moment:
The first stage is a SPDT switch, and the second is a SPST switch, both using lumped element quarter wave impedance transformers. Diodes D1 through D4 are all MA4P7470F-1072T PIN diodes. Explanations for the operation of both switch types can be found here: **broken link removed**
The circuit can switch from receive to transmit very quickly (few us), but when going from transmit to receive, I see ringing on the output at my 10MHz frequency of interest, which lasts around 30-50us before dropping below my noise floor. This ringing persists even if I am not transmitting any thing, and the coil is not attached (I just put 50ohm terminators on the TX and Coil ports). Therefore that transient ringing must originate in the TR switch itself during the switching event, I think.
I'd like everything to be quiet in 10us or less. Is there anything I can do hear to either damp the ringing, or reduce its amplitude, without severely impacting the performance of the circuit (mainly its loss from the coil port to the LNA port)?
Thanks in advance
