When you build the Pad for these Packages, you just need to have at least 10 mils to 30 mils extra for each side to make sure the Assembly can be soldered them. You can use the length for these Pads from 60 to 80 mils, so it can cover all. The width is depended on the Pin. That's the key to build Parts on Power PCB.
