Recommended footprints - any website?
kkdelabaca
Full Member level 2
ssop8 footprint
Hello,
somebody knows a Web where recommend the footprints of the components? (sot23, PLCC, 1206, ...)
Regards!
Re: Recommended footprints
kkdelabaca said:
Hello,
Regards!
Find a part that uses the foot print and look at the data sheets from the manufacturer most times there is a recomended foot print
pd
Hi Here are some documents that I have don't think it is still on internet since I am not able to find a link for it anymore that is why I post it here.
Always check your component datasheets since sometimes the chips don't have the same footprint as your lib. ssop 8 is not always the same between different vendors.
regards,
Paul.
Thanks PaulHolland & phonedrop,
indeed some times I have found the footprint in the datasheet.
You know some names of the manufacturers who put the recommended footprint in the datasheet?
For example: http://www.irf.com/package/pkdstdrec.html
Regards!
here is what i've found long time ago
Hope this will help you
