Re: Power Relays
Thank you, I had looked at SSR for a bit and they have much nicer datasheets I will admit, but I do not know if a Solid state circuit would beable to handle an inductive load switching on and off rapidly. Will this not cause a large voltage spike and blow the part?
And as for the power relays if TTL is not possible just ignore that spec, I was just being hopeful as it would make control very easy I could aways get a driver of some kind to switch an mechanical relay the required more power to switch.
Thanks and any more input is most welcome.
