Recommend a RF 2x1 power combiner
jlovejoy
Does anyone know of a power combiner type that can combine two signals with same frequency but different phase? Wilkinson's can do it but they have up to an additional 3dB loss for out of phase signals which I am trying to avoid. Now let me add some additional constraints.
Ideally - just microstrip lines and octave bandwidth (10-20 GHz)
Can't have - active components
Don't want - resistors, caps, etc.
I also want a couple million bucks but I realize I can't have eveything so any ideas are welcome. :D
Thanks
Jim
Re: RF 2x1 power combiner
Its easier to get millions of bucks instead of a no-loss passive power combiner.
Reactions: Edd
    Edd
I realize there will be some loss.
Let me get more specific on what I want to do. I have two microstrip signals to combine, A and B. Both A and B have same frequency but are 180 degrees out of phase. I want to combine A and B onto one microstrip line. Destructive interference should make the signals go to zero once combined. However, sometimes A is off and sometimes B is off. So when A or B is off, I want the other to be on the output.
Is there a way to do this passively? If not, could you point me in the direction of active possibilities.
Thanks
Is signal A always >180° or is signal B always >180°
if so you can use a 180° combiner
