Receiving PUi5 from GSM modem
mvpradeepemb
Newbie level 1
Dear All,
I am interfacing Atmega16 with GSM modem(SIM900). Modem works fine with hyperterminal. Controller also transmits and receives good with hyper terminal. But when i interface controller with gsm, i receive "PU8" and "PUi5" when i transmit "AT" & "AT+CFGM=1".
int main(void)
        init();
        lcd_init();
        sei();
        set_timer2();
        ptr=gett;
        usart_init(myubrr);
        step=0;
       command(0x01);
       command(0x80);
    while(1)
        if (!(PINA & (1<<PINA0)))
                command(0x01);
                command(0x80);
       if(step==0)
               step=1;
               usart_transmit('A');
               delay(100);
               usart_transmit('T');
               delay(100);
               usart_transmit(13);
 if (!(PINA & (1<<PINA1)))
                command(0x01);
                command(0x80);
        if(step==1)
                 step=2;
                 delay(50);
                 delay(50);
                 usart_transmit('+');
                 delay(50);
                 usart_transmit('C');
                 delay(50);
                 usart_transmit('M');
                 delay(50);
                 usart_transmit('G');
                 delay(50);
                 usart_transmit('F');
                 delay(50);
                  usart_transmit('=');
                 delay(50);
                 usart_transmit('1');
                 delay(50);
                usart_transmit(13);
void init(void)
  DDRB=0xFF;
  PORTB=0xFF;
  PORTC=0xFF;
  DDRC=0xFF;
  DDRA=0x00;
  PORTA=0xFF;
  PORTD=0x00;
  DDRD=0x3C;
void delay(const long del)
  long x;
  int y,z;
  for(x=0;x<=del;x++)
     for(y=0;y<=254;y++)
     for(z=0;z<=254;z++);
  return;
void USART_Flush( void )
   unsigned char dummy;
   while ( UCSRA & (1<<RXC) ) dummy = UDR;
void usart_init(unsigned int ubrr)
 UBRRH=(unsigned char)(ubrr>>8);
 UBRRL=(unsigned char)ubrr;
 UCSRB=(1<<RXEN)|(1<<TXEN)|(1<<RXCIE);
 UCSRC = (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1); //(1 << URSEL) }
void usart_transmit(unsigned char datat)
  while(!(UCSRA & (1<<UDRE)));
  UDR=datat;
//unsigned char usart_receiver(void)
ISR(USART_RXC_vect)
    rec=UDR;
    display(rec);
I also tested using vb6. I transmit chr(10) + chr(13) + "OK" + chr(13) + chr(10) from vb6. I receive $$OK$$ in MCU. But i do know why i am receive PU8 and PUi5 in MCU.
