receiver design query
bizoo
Member level 5
Member level 5
HI guys i am right now studying different waveforms going into the receiver.
This is a high freq receiver and its input is a signal of 5GHZ and its out put is 11 Mhz signal(baseband signal)
Now i found out the receiver had 4 output pins going in the baseband processor,
2 are for in phase part (I signal) and 2 are fpr out of phase part (Q signal)
my query is that why a receiver has 2 pins each for both I and Q signal
one of these 2 pins is +ve voltage and the other is same wave but with -ve voltage,
So i wonder what effect will it have when i have these 2 waves but with opposite polarity go into the baseband processor, and how this schme is differernt for the case when I and Q signal have only one pin each
br
THe baseband I/Q output is differential. The baseband information is carried in the voltage difference between these two signals. The A/D input in the baseband needs to have a differential input to match.
If you have a single pin for I and a single pin for Q, then the information is between the signal and ground. Same information, different representation
Dave
www.keystoneradio.com
Thanks for the answer
regarding input for A/D, what will happen if i add (or subtract) the signals and then fed this signal into the A/D rather than making sure that A/D accepts differential input.
Subtracting the two signals will give me the original signal, will this scheme work the same way as compared to having differential input for my A/D
Differential operation gives many advantages when designing integrated circuits because transistors can be matched one by one. It can result in better linearity and dynamic range. Therefore it is not a good idea to convert to single ended. Use a differential buffer (ADC driver) instead and find a suitable ADC with differential input. Most high speed converters have differential input anyhow.
LaTeX Commands Quick-Menu:
