Reading SPEF in primetime
dcreddy1980
Full Member level 5
Munich, Germany
primetime & spef
I have SPEF and verilog gatelevel netlist after the place and route...is it a good idea to do STA with these two files...or we should perform STA with verilog and SDF files only.....???
ex :
read_verilog test.v
read_parasitics -keep_capacitive_coupling test.spf
primetime spef
primetime read spef
set_load file usually should be read
spef primetime
generally, when reading SPEF, the STA tool does an internal RC extraction before processing with timing calculation. In certain instances, some clock transitions may be modelled ideal if the clocks are defined on output pins(see solvnet). Reading SDF is more straight forward and it corresponds well to timing simulations.
prime time spef
sdf is the outcome of calculating the RC,but SPEF is the data of RC.
primetime read_parasitics -path
SPEF has parasitic information. only capacitance and resistance values are annotated on the nets when you use spef and the cell delay come from library and calculted based on loading of each cell. With SDF all net delays are annotated as if they are absolte values as calculated and included in SDF file. In short SPEF is more accurate that SDF.
primetime spdb spef read
yes, I agree rakko. SPEF is more accurate than SDF.
sdf is more optimistic.
read spef file in primetime
You should do STA with SPEF only.SDF is optimistic where as SPEF will give you the accurate analysis
reading spef file
use read_verilog to read your verilog netlist
use read_parasitic to read your spef file.
SDF can be generated in PT
reading sdf
sdf file generated by PT have less accuracy.
signal storm can read spef file to generate more accurate sdf.
signal storm's ability to calculate delay is more powerful than PT.
