[SOLVED] Reading negative hex values in Verilog!Plz HELP
UFK
Member level 3
Pakistan
Hi All
In my code im using $readmemh to read hex values from a text file in which alot of the values are negative. Verilog is treating them as positive and returning erroneous results. Can someone please help me deal with this problem? I really need to figure out a way to recognize these negative hex values.
Please help
fcfusion
Full Member level 4
When dealing with negative numbers in verilog (either decimal or hex) you must indicate explicitly that you are using signed numbers. To do that you just have to declare your variables as signed:
"reg signed [7:0] var"
Do the same for input or output signals:
"input signed [7:0] var"
UFK
Member level 3
Pakistan
Thankyou so much.
I tried what u suggested but it still wont work correctly for neg values.
I am posting my code below along with the text file its supposed to read. Perhaps you could run it to see what can be fixed in it.
1. This code should compare text file values with the constant T.
2. If greater than T, then move to LSP else do nothing
The code works fine if text file has positive hex values only, but with neg as in my case its not giving correct results.
My code is
module test();
reg [31:0] Signbit_ctr;
reg [31:0] Bit_ctr0;
reg [31:0] Bit_ctr1;
reg[31:0] T=32'h00001000;
integer i;
integer k;
reg signed [31:0] LIP [0:3];
reg signed [31:0] LSP [0:1023];
initial $readmemh("D16.txt",LIP);
initial
begin
Signbit_ctr = 0;
Bit_ctr0 = 0;
Bit_ctr1 = 0;
end
always @ (LIP)
begin
for(i=0;i<=3;i=i+1)
if (LIP >= T)
begin
LSP = LIP;
Bit_ctr1 = Bit_ctr1 + 1;
Signbit_ctr = Signbit_ctr + 1;
end
else
begin
Bit_ctr0 = Bit_ctr0 + 1;
$display("%d:%h",i,LSP);
end
end
endmodule
and the text file D16.txt is
12F2
FFFFFD3E
FFFFFF78
FF
Thanks alot in advance. And thankyou for all the previous help too. :)
