aq_mishu
Full Member level 4
Guys,
I'm looking for a solution to read AC 220 mains voltage. Basically i have around 50 places where i have to read the voltage. Please consider the following:
1) i'm well aware of the mains and isolation issues.
2) I am using a full bridge transformerless psu for uC (mega8). Means N is not grounded.
3) for voltage reading, I just need the rms volt, and i dont need to know 220 or -220 (means a DC measurement is fine)
4) i can not use transformer due to cost and circuit physical dimentioning issues.
5) incase of op amp based reading, i can use 741 or such, with single pwr as 5v only.
6) i can not tie N to gnd as i will use RS232 and that may make trouble to interface with PC.
I already have searched a lot. One i found was a enegrymeter. Bt that will not work for me as N is tied to gnd. Also, i can not use advanced pwr measuring ICs from AD or such as they are not available at market. Also price is an issue. So guys, can somebody help me out?
Also, if i use a cap after live and a resistor of 100ohm, (like transformer less psu), then will it up/down according to change in 220?
I can not make a resistor devider as that will make it real complex, when im scaling 220v down to some 2.2 v. Ideas??
Mishu.
Mishu.
