Reading from and writing to RFID tags
MohammadElwakeel
Junior Member level 1
writing to rfid
Dear All,
I have a question about RFID. I'm using TRF7960 reader chip. My question is:
I've succeeded to program the reader registers, configured it to ISO14443-A protocol. I was able to send REQA command and got the response from the tag, I sent SELECTS command and the tag responded. now the tag is selected but I don't know how to write or read data from the memory of the tag, can anybody tell me please, how to write to some certain address in the tag or read from a certain address.
Thanks so much, please anyone with any small piece of information, reply and say it.
FvM
Super Moderator
Staff member
Bochum, Germany
rfid writing
ISO14443 doesnt't specify a particular application level protocol, e.g. to interface memory cards. Typically protocols as ISO7816 (a standard for contact cards) or Philips Mifare are used. Refer to the documentation of your memory card and respective TRF7960 application information.
MohammadElwakeel
writing on iso-14443 card
Dear FvM,
thank you for your reply. I need to ask you two questions:
1- Is it true that in order to communicate with mifare cards, the reader chip must be philips ASIC?
2- would you suggest me some RFID that comply with ISO 14443-A with memory of about 1kbyte? please, suggest some easy tag to interface with.
Thanks so much and best regards
rajan_pec
Junior Member level 2
India
trf7960 14443 register
MohammadElwakeel said:
Dear All,
hi,
I am also working on TRF7960 RFID IC.
I am using PIC18F4420 to control the TRF7960, but having some problems in
reading.
Which controller are you using to control TRF7960??
Regards,
rajan
heronx
writing tag data to rfid tags
Hello, I'm working with this chip also, I'm using atmega128 & trf7960, I can also read and write registers but I cannot read anything from tags. Are you setting some other registers than ChipStatusControl and ISOControl before transmiting REQA???
please reply
Thanks in advance!
dsktchef
Newbie level 3
how to read rfid tag
ISO 14443A does not specify, how to read or write data. ISO 15693 does, but for ISO 14443A, you need the datasheet of the tag. There, the command sequence will be described.
@Heronx: What exactly do you send to the tag? Do you have an oscilloscope for watching the data?
Tom
heronx
how to write rfid tag
Hi, I have opened new post, there are details:
mskj786
Newbie level 2
Rawalpindi
Re: writing to rfid
Dear u have to use the writer to write in the memory chip
Can u tell me which chip u have used
i mean model nmbr of the chip
ant tell me one thing when u matced the chip impedance
have u used the opposite sign from imaginary part or the same sign
Regards Saeed Khan
