reading file using textio package
vivo_m
Member level 3
hello everybody,
i'm trying a simple example to read std_logic_vector from a file and retrieve its equivatent integer value
but there is an error in read() and readline().. actually when i tried to compile textio package i got this error msg
# ** Error: (vcom-7) Failed to open design unit file "D:/vhdl projects/vhdl_src/std/textio.vhd" in read mode.
# No such file or directory. (errno = ENOENT)
# C:/modeltech_6.5/win32/vcom failed.
any idea how can i overcome this plzzz..
i found that there is an additional library for textio its "standard_textio_additions", i also used it but with same error
any help plzzz
thanks...
TrickyDicky
Advanced Member level 5
you dont need to compile textio, its already included in modelsim.
the standard_textio_additions is a VHDL 1993 version of the VHDL 2008 additions. A newer version of modelsim will support this by default (so you dont need to include it).
vivo_m
Member level 3
i'm working on version 6.5.. and i actually all of ieee_proposed library packages are not included that's why i added standard_textio_additions
here is my code
library ieee;
use ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;--conv
USE ieee.std_logic_unsigned.all;
use std.textio.all;
LIBRARY ieee_proposed;
USE ieee_proposed.standard_textio_additions.all;
entity FILEREAD is
  --generic (stim_file : string  :=  "sim.txt");
  port(
       CLK              : in  std_logic;
       RST              : in  std_logic;
       Y                : out std_logic_vector(4 downto 0);
       X                : out integer;
       EOG              : out std_logic
end FILEREAD;
architecture read_from_file of FILEREAD is
type read_file is file of std_logic_vector(4 downto 0);
   signal eog_sig :std_logic;
begin
  process (clk)
    file stimulus : read_file open read_mode is "sim.txt";
    variable l: line;
    variable s,Y_sig: std_logic_vector(4 downto 0);
    begin
      if (rising_edge(clk)) then
        if rst = '1' then
          EOG_sig <= '0';
          X <= 0;
          Y <= (4 downto 0 =>'0');
        else
            while not endfile(stimulus) loop
              -- read digital data from input file
              READLINE(stimulus, l);
              READ(l, s);
              Y_sig := s;
              Y<=Y_sig;
              X <= conv_integer(Y_sig);
              --wait until CLK = '1';
            end loop;
            EOG_sig <= '1';
          end if;
          EOG <= eog_sig;
      end if;
    end process;
end architecture;
whenever i compile it it gives me this erroe
** Error: D:/vhdl projects/readingValues.vhd(62): No feasible entries for subprogram "readline".
** Error: D:/vhdl projects/readingValues.vhd(63): No feasible entries for subprogram "read".
would you plz help me to find where the problem is..
thanks
TrickyDicky
you need to include ieee_proposed.std_logic_1164.additions.all; for textio with std_logic.
vivo_m
Member level 3
still having the same error about readline()
i though that the problem may be with the file i want to read??
well its .txt containing this data
"00010 00011 11100 10000 00111 11111"
i tried saving it like above and saving it like that
00010
00011
11100
10000
00111
11111
nothing change still giving me this msg
"No feasible entries for subprogram "readline"."
any idea ????
TrickyDicky
oops, I misread. There is no such thing as a "read_file" type, the file type is "text"
file stimulus : text open read_mode is "sim.txt";
PS. why dont you upgrade to a more recent version of modelsim, ie. 10.1d? then you dont need the ieee_proposed library (because it has native VHDL 2008 support).
Reactions: vivo_m
    vivo_m
vivo_m
Member level 3
if so,,, there will be no need to write this line of code
"type read_file is file of std_logic_vector(4 downto 0);" or wt??
well its compiled :)
but when i started simulating it stopped at "READLINE(stimulus,l)" giving me this msg
#** Fatal: (SIGSEGV) Bad handle or reference.
# Time: 600 ns Iteration: 0 Process: /fileread/line__44 File: D:/masters code/vhdl projects/readingValues.vhd
# Fatal error in Process line__44 at D:/masters code/vhdl projects/readingValues.vhd line 63
# HDL call sequence:
# Stopped at D:/vhdl projects/readingValues.vhd 63 Process line__44
i don't know what to do :(
would you plz try it for me and tell me whats wrong and how to overcome it plzzz??
thanks
actually i don't have its source :$
i know its an old version but its the only licensed one i've :s
TrickyDicky
Your file type declaration isnt needed because you're reading std_logic_vectors from a text file. It is only required if you want to read from a data file (and I wouldnt recommend doing that).
A SIGSEGV is usually a modelsim crash. So I would highly suggest upgrading your version of modelsim. You licence should cover all versions. The error doesnt correspond to aa line in the code you posted.
vivo_m
Member level 3
Thanks alot i will find out an updated source and let you know the updates..
thanks alot TrickyDicky :)
