Reading Data using I2C
Micro Lover
Member level 2
pakistan
hi
i m using 89C2051
i want to read the temperature using i2c in Keil uVision4
is there any simplest code ? // In C
i mean just send address and read data
no more
karthikkrv85
Full Member level 3
bangalore
Hai
Please use this following code
// I2C Functions - Bit Banged
// 	Routine:	i2c_start
//	Inputs:		none
//	Outputs:	none
//	Purpose:	Sends I2C Start Trasfer - State "B"
void i2c_start (void)
	SDATA = HIGH;							// Set data line high
	SCLK = HIGH;							// Set clock line high
	SDATA = LOW;							// Set data line low (START SIGNAL)
	SCLK = LOW;								// Set clock line low
// 	Routine:	i2c_stop
//	Inputs:		none
//	Outputs:	none
//	Purpose:	Sends I2C Stop Trasfer - State "C"
void i2c_stop (void)
	unsigned char input_var;
	SDATA = HIGH;							// Set data line high (STOP SIGNAL)
	input_var = SDATA;						// Put port pin into HiZ
// 	Routine:	i2c_write
//	Inputs:		output byte
//	Outputs:	none
//	Purpose:	Writes data over the I2C bus
void i2c_write (unsigned char output_data)
	unsigned char index;
	for(index = 0; index < 8; index++)  	// Send 8 bits to the I2C Bus
                                 			// Output the data bit to the I2C Bus
		SDATA = ((output_data & 0x80) ? 1 : 0);
      	output_data  <<= 1;            		// Shift the byte by one bit
		SCLK = HIGH;   		        		// Clock the data into the I2C Bus
		SCLK = LOW;
	index = SDATA;							// Put data pin into read mode
	SCLK = HIGH;   		        			// Clock the ACK from the I2C Bus
	SCLK = LOW;
// 	Routine:	i2c_read
//	Inputs:		none
//	Outputs:	input byte
//	Purpose:	Reads data from the I2C bus
unsigned char i2c_read (void)
	unsigned char index, input_data;
	input_data = 0x00;
		input_data <<= 1;					// Shift the byte by one bit
      	input_data |= SDATA; 		   		// Input the data from the I2C Bus
		SCLK = LOW;
   return input_data;
I hope you will be knowing how to assign the port pins to the SDA and SCL and also the transferring ways
All the best
