I want to read analog values that are being taken in by the PIC 18f4550. I am taking input from a LED which I am using as a Photosensor. Can someone tell me how i should proceed to view the inputted analog data values in MPLAB?
You should go through the Gooligum Tutorials. They are excellent and after you go through them, you should be able to use the ADC for your application with ease.
**broken link removed** **broken link removed** **broken link removed**
Iam using Microchip c18 compiler.
Thank you for the tutorials. But I want to know if there is any way i can see the output values of the ADC in MPLAB itself instead of an LCD display as mentioned in the tutorial?
