i want to read digital data of LM35 sensor which is attached with my ADC0808 through microcontroller 89s51.
How can i do that....?
For example my ADC0808 data pins D0-D7 are connected with port0 of uC.
How should the code look like....?
For instance if ur Data lines (D0-D7) is connected to port 0...The next thing is to connect the address lines to another port of ur 8051..Some control pins must also be connect to any port such as (start,clock,ALE,OE)...Then u have to make a prog that will refresh the ADC to take new values of LM35 and then u read the data from ur port 0... Try reading ADC0808 data for timming and controls. They are necessary...
