Read to an array from serial port and a can baud rate calculation
Magvitron
Full Member level 5
Full Member level 5
Kollam (Quilon), India, India
Hi, I am building a CAN n/w using pic 18f25k80. Can any one help in the following
1. Calculating the baud rate of CAN
my current setting
//Setup the Baud Rate @16 Mhz.
    BRGCON1 = 0xc3;
    BRGCON2 = 0x9e;
    BRGCON3 = 0x03;
2. How to read from the UART to an array
my current code (this is not working) ie there is no update in array.
Initialize the serial port
@ 160000 and 230400bps
Requires :none
Returns : none
void uart_init()
{//Enables Serial port
/*RCSTA RECIEVER CONTROL REGISTER*/
RCSTA1bits.SPEN = 1;
RCSTA1bits.RX9=0;//8 bit reception
RCSTA1bits.CREN = 1; //enable the reciever
  TRISCbits.TRISC7=0;
  TRISCbits.TRISC6=0;
/*TXSTAx: TRANSMIT STATUS AND CONTROL REGISTER */
TXSTA1bits.BRGH=1;//baud rate high bits
TXSTA1bits.SYNC=0;//assynchronous mode
TXSTA1bits.TX9=0; //8 bit reception
TXSTA1bits.TRMT=1;//reset the buffer
TXSTA1bits.CSRC=0;// Master mode  (clock generated internally from BRG)
/*BAUDCONx: BAUD RATE CONTROL REGISTER*/
BAUDCON1bits.BRG16=1;//16 bit Baud rate is enabled
SPBRGH1 = 0;
SPBRG1 = 16;//2;
//(((_XTAL_FREQ/baud)/4)-1);
//FCY/64)/BAUD) - 1;
// set baud to 9600  FCY=20000000
//Turn On the Tx and Rx
TXSTA1bits.TXEN=1;
RCSTA1bits.CREN=1;
//Function for read to a buffer
//Requires  : <Xc.h>,Uartinit
//Returns  : None
//Parameters: None
void uart_read2buff()
int count;
while(uart_read()>0)
  rxr[count]=uart_read();
  uart_char(uart_read());
  count=count+1;
  uart_num(count);
  if (count>63)
  break;
uart_string("out of here");
rxr[count]='\0';
count=0;
//Function for sending char
//Returns  : None
//Parameters: None
void uart_char(char data)
TXREG1= data;
  while(!TXSTA1bits.TRMT);
//Function for reciveing from serial
//Returns  : None
//Parameters: None
char uart_read()
while(!RC1IF);
RC1IF=0;
return RCREG1;
//RCSTA1bits.CREN = 0;
//RCSTA1bits.CREN = 1;
can any one point out how to do it?
P.S. I'm using XC8 compiler basic.
