Read operation of a memory and clock cycles
sky_above
Member level 2
Is the for RAM and other memories the clock edge at which the memory captures the address in the same clock cycle it will provide the read data for a read operation? Is there any memory where the read data will be given in the next clock cycle just after the clock cycle at which the memory captures the address? What type are memory are those where it happens?
A synchronous RAM without output registers provides the read data shortly after latching the read address.
For sure you are free to add extra logic to generate the desired delay by one clock cycle. But what's the benefit?
Klaus
