read bitmap from university program sdcard de2 nios
yupina-chan
Member level 2
Member level 2
hi. i want to read a bitmap image from my sdcard. i was able to write to sdcard as in the tutorial. my source code for reading is as follows:
#include <stdio.h>
#include <system.h>
#include <altera_up_sd_card_avalon_interface.h>
#pragma pack(2)
typedef struct{
unsigned short int type; /* Magic identifier */
unsigned int size; /* File size in bytes */
unsigned short int reserved1, reserved2;
unsigned int offset; /* Offset to image data, bytes */
} BMPFileHeader;
typedef struct{
unsigned int size; /* Header size in bytes */
int width,height; /* Width and height of image */
unsigned short int planes; /* Number of colour planes */
unsigned short int bits; /* Bits per pixel */
unsigned int compression; /* Compression type */
unsigned int imagesize; /* Image size in bytes */
int xresolution,yresolution; /* Pixels per meter */
unsigned int ncolours; /* Number of colours */
unsigned int importantcolours; /* Important colours */
} BMPInfoHeader;
short int sd_fileh;
short int header;
int x;
int main()
printf("SD Card Access Test\n");
alt_up_sd_card_dev *sd_card_dev = alt_up_sd_card_open_dev(SD_CARD_NAME);
if(sd_card_dev != 0)
if(alt_up_sd_card_is_Present())
if(alt_up_sd_card_is_FAT16())
printf("Card is FAT16\n");
else
printf("Card is not FAT16\n");
sd_fileh = alt_up_sd_card_fopen("pic.bmp", false);
if (sd_fileh < 0)
printf("Problem creating file. Error %i", sd_fileh);
else
printf("SD Accessed Successfully, reading BMP image...");
for(x=0;x<54;x++)
header = (unsigned char)(alt_up_sd_card_read(sd_fileh));
printf("Size: %ld\n", sizeof(BMPFileHeader));
printf("Done!\n");
printf("Closing File...");
alt_up_sd_card_fclose(sd_fileh);
printf("Done!\n");
return 0;
it builds without errors and the sd card was accessed successfully but the returned bitmap size was wrong. my image is 20.3 kb while the returned size was 14kb. please guide me in correcting my code especially in the reading part. im not familiar with c. thanks in advance!
my
#include <stdio.h>
#include <system.h>
#pragma pack(2)
typedef struct{
} BMPFileHeader;
typedef struct{
} BMPInfoHeader;
short int sd_fileh;
short int header;
int x;
int main()
else
if (sd_fileh < 0)
else
for(x=0;x<54;x++)
printf("Done!\n");
printf("Done!\n");
return 0;
my
i amazed how you managed to come so far without knowing c...
so i guess it's learning time now for you, just loo for some c tutrials...
thank you for the reply but i think ive read enough c tutorials now but i still cant get it right. my problems are:
returns an int
and the fopen cannot be used.
i dont know how to translate this:
filePtr = fopen(filename,"rb");
and
fread(&bitmapFileHeader, sizeof(BITMAPFILEHEADER),1,filePtr);
i know the functions of these in c but in hal, i dont know where to put this or use this.
see my sugestions : problems 1 and 2
Code C - [expand]
short int sd_fileh;
returns an int
Code C - [expand]
short int filePtr;
filePtr = alt_up_sd_card_fopen(filename, false);
and
Code C - [expand]
short int byte_to_read[100];
for(i=0;i<sizeof(BITMAPFILEHEADER);i++)
  byte_to_read[i] = alt_up_sd_card_read(filePtr);
hope i helped....
