Qwidgybo
Hi All,
I have bought a 3v (2 X 1.5 v AA batteries) hand fan and also bought a USB phone charger, cut off the phone charger bit, and am trying to get the USB cable to power the hand fan without burning out the motor. Initially I just hooked the red/black cables to the corresponding points on the fan - I call that "Fan No.1" now. Fan No.2, I got a potentiometer from my local Maplins (electronics shop in the UK) and when I wired it up it worked, but had a very, very short "adjustment" phase on turning the knob, that, and it started to smoke and glow red. I did tell the guy at Maplins what it was for so I don't know why he gave me the pot that wasn't the correct voltage or whatever. Got a refund on the pot and bought 3 resistors, a 100ohm, 150ohm, and 300ohm (based on some googling of people attempting similar projects). I think those are the levels, I asked for them but the 100 one looks like it might actually be a different ohm level the colors on it are brown-brown-black-black and what looks like either brown or a darker shade of brown. Which confused me, but anyway. I tried hooking fan no.2 up with the resistors in between the positive and negative wires but the fan wouldn't turn at all, tried jiggling the connections etc no joy. It did work when I briefly touched the pos/neg usb cables directly to the motors points so I know the fans motor is operative, however I only ran it for a second so as not to move onto fan no.3.
This is just a fun project for me, I know I can buy a USB fan for £3 or whatever, I just like tinkering - any ideas on what level of ohms would work if I was to use a resistor or is there some easier way to reduce the voltage from 5 to 3 - keeping in mind I don't own a soldering iron, don't really want to buy a breadboard or make a proper circuit, although if it is really simple/cheap I'd be ok with that... it's just a very simple project and I want to keep it cheap-ish.
I have also done a search of your forums for "reduce 5v to 3v" but couldn't find anything that would help.
Any ideas?
Qwidgybo
Any ideas?
Qwidgybo
