Re use of PGC and PGD pins as output for PIC32MX250F128D
rajib.das
Member level 3
Member level 3
Hi Everyone
I am new with PIC32MX250F128 44Pin. Recently working with a projects which is getting bit tight on pin availability demands to find a scope of re using the PGC1 and PGD1 as output pins contain resister and capacitor to the physical circuit.
Do you guys have any Idea what are the problems I may get into?
These pins are not strictly reserved only to the core programming, but it is relativelly usual share to other output functions which do not affect its further working. Anyway, once the R-C components you mentioned above tends to degrade the ICSP signals, probably would not work specifically for this case.
