alexan_e
Administrator
RElease Check My N-Channel MOSFETs H-Bridge Schematic Diagram
In your other post in allaboutcircuits you have also been suggested to use a gate voltage higher that the drain voltage, you didn't accept it there either, you want to do it your own wrong way.
1/4 of your power will be consumed as heat on the high side mosfet if you keep using the drain voltage to provide the gate bias in the high side Nmosfet.
Alex
You have closed your thread so I can only post an answer this wayWell, I thought I was receiving pieces of information to help me with my circuit. But it turned out to be NOT
Alex
