Re: Converting inductance to microstripline
kelvchan
Member level 3
Hi, I wish to convert inductance value to its equivalent length of microstrip line with a given substrate height and dielectric permittivity, any closed form expression?
Values are:
Inductance Value: 0.87nH
Substrate height: 0.35mm
Thanks
mauloftin
Full Member level 6
CZ
1) series inductance
2) parallel inductance
L = (Zl * l/vf) = (Zl * l *√εef)/c
for Zl>>Zv, l <<λg
g86
Full Member level 4
On top of antenna :))
If load is close to zero then inductance≈j\[Z_o\]tanβl. Otherwise better to use a simulator.
PeterMartin
Member level 1
UK
In principle inductances can be approximated by high impedance transmission line but its is only an approximation. The higher the line impedance the better the approximation.
BUT
High impedance microstrip lines, which are thin, can be lossy and are not capable of handling high power. So its often worth considering if there are other possibilities.
