burrow
Full Member level 2
Hai , i was making an A/V selector switch that will be controlled my microcontroller.
I will be using SPDT relays each for Video, left ,and right.
The NO and NC contact of relay will go to 2 different sources. So my question is will this configuration give out any sort of noise (because inside the relay the contacts might be close so will they interfere )
also can i tie grounds of all sources together or should i go for a relay for selecting ground too ?
