RC5 Remote transmitter Help..!!
parthiv2eng
Member level 2
Houston
Here's code and circuit dia...But it won't work..please help..!!
#include<htc.h>              //include MCU head file
__CONFIG(OSC_XT & WDT_OFF & CP_OFF);
#ifndef _XTAL_FREQ
 // Unless already defined assume 4MHz system frequency
 // This definition is required to calibrate __delay_us() and __delay_ms()
 #define _XTAL_FREQ 4000000
#endif
#define	PLAY		0x35
#define STOP 		0x36
#define PAUSE 		0x30
#define PREVTRACK 	0x21
#define NEXTTRACK 	0x20
#define REVERSE 	0x32
#define FASTFORWARD 0x34
#define SHUFFLE 	0x1C
#define REPEAT 		0x1D
#define VOLUMEUP 	0x14
#define VOLUMEDOWN 	0x15
#define MUTE 		0x0D
#define PROGRAM		0x24
#define STANDBY		0x0C
#define	DIM			0x10
#define DISC		0x2D
#define SCAN		0x2B
#define SOURCE		0x0E
#define PARITY		0x0A
#define AORB		0x3B
#define TIME		0x29
#define FAST		0x2F
#define UNDEFINE	0xFF
#define ADDRESS		0x14
#define FALSE		0
#define TRUE		1
void send_code(unsigned char);
void transmit(unsigned char);
typedef struct
	unsigned char bit_mask;			//used to create a serial data stream
	unsigned int k;
	unsigned int count;
	unsigned char key;
	unsigned char row;
} REMOTE;
volatile REMOTE remote;
                             //main program
void main()
  while(1)                   //circle work
		TRISA=0x00;                 //PORTA OUTPUT
		TRISB=0xFF;                 //PORTB INPUT
		TRISC=0x00;                 //PORTC OUTPUT
		RA3 = 1;
		remote.key = 0;
      	for( remote.row = 0b00000001; remote.row < 0b01000000; remote.row<<=1)
				RC0 = 0;
				RC1 = (~remote.row)>>1;
				RC2 = (~remote.row)>>2;
				RC3 = (~remote.row)>>3;
				RC4 = (~remote.row)>>4;
				RC5 = (~remote.row)>>5;
				RC6 =	1;
				RC7 =	1;
 			// read colums - break when key press detected
        	if(RB0)break;  remote.key++;
        	if(RB1 )break;  remote.key++;
			if(RB2)break;  remote.key++;
			if(RB3)break;  remote.key++;
			if(RB4)break;  remote.key++;
			if(RB5)break;  remote.key++;
			if(RB6)break;  remote.key++;
			if(RB7)break;  remote.key++;
   		RC1 = 1;
    	RC2 = 1;
    	RC3 = 1;
    	RC4 = 1;
		RC5 = 1;
	  switch(remote.key)
			case 0:		send_code(UNDEFINE); break;
			case 1:		send_code(STANDBY); break;
			case 2:		send_code(UNDEFINE); break;
			case 3:		send_code(UNDEFINE); break;
			case 4:		send_code(DISC); break;
			case 5:		send_code(UNDEFINE); break;
			case 6:		send_code(UNDEFINE); break;
			case 7:		send_code(AORB); break;
			case 8:		send_code(UNDEFINE); break;
			case 9: 	send_code(1); break;
			case 10: 	send_code(4); break;
			case 11:	send_code(7); break;
			case 12: 	send_code(UNDEFINE); break;
			case 13: 	send_code(SCAN); break;
			case 14: 	send_code(FAST); break;
			case 15: 	send_code(SHUFFLE); break;
			case 16: 	send_code(UNDEFINE); break;
			case 17: 	send_code(2); break;
			case 18:	send_code(5); break;
			case 19:	send_code(8); break;
			case 20:	send_code(0); break;
			case 21:	send_code(PROGRAM); break;
			case 22:	send_code(REVERSE); break;
			case 23:	send_code(PREVTRACK); break;
			case 24:	send_code(UNDEFINE); break;
			case 25:	send_code(3); break;
			case 26:	send_code(6); break;
			case 27:	send_code(9); break;
			case 28:	send_code(UNDEFINE); break;
			case 29:	send_code(TIME); break;
			case 30:	send_code(FASTFORWARD); break;
			case 31:	send_code(NEXTTRACK); break;
			case 32:	send_code(REPEAT); break;
			case 33:	send_code(PAUSE); break;
			case 34:	send_code(STOP); break;
			case 35:	send_code(UNDEFINE); break;
			case 36:	send_code(UNDEFINE); break;
			case 37:	send_code(UNDEFINE); break;
			case 38:	send_code(UNDEFINE); break;
			case 39:	send_code(UNDEFINE); break;
			case 40:	send_code(PLAY); break;
			case 41:	send_code(UNDEFINE); break;
			case 42:	send_code(UNDEFINE); break;
			case 43:	send_code(UNDEFINE); break;
			case 44:	send_code(UNDEFINE); break;
			case 45:	send_code(UNDEFINE); break;
			case 46:	send_code(UNDEFINE); break;
			case 47:	send_code(UNDEFINE); break;
			default:	break;
void send_code(unsigned char button)
	 //BUTTON DOWN
	remote.bit_mask = 0x10;
	// Send two start bits
	RA3 = FALSE;
	__delay_us(889);
	RA3 = TRUE;
	__delay_us(889);
	RA3 = FALSE;
	__delay_us(889);
	RA3 = TRUE;
	__delay_us(889);
	// Send a toggle bit - 1
	RA3 = FALSE;
	__delay_us(889);
	RA3 = TRUE;
	__delay_us(889);
	// Send address - 5 bits
	for (remote.k = 0;  remote.k < 5; remote.k++)
		if ((ADDRESS & remote.bit_mask) > 0)
				RA3 = FALSE;
				__delay_us(889);
				RA3 = TRUE;
				__delay_us(889);
		else
				RA3 = TRUE;
				__delay_us(889);
				RA3 = FALSE;
				__delay_us(889);
		// Shift remote.bit_mask right 1 bit 0x10->0x08->0x04->0x02->0x01
		remote.bit_mask = remote.bit_mask >> 1;
	//Send button command
	remote.bit_mask = 0x20;
	// 6 data bits, MSB first
	for (remote.k = 0;  remote.k < 6; remote.k++)
		if ((button & remote.bit_mask) > 0)
				RA3 = FALSE;
				__delay_us(889);
				RA3 = TRUE;
				__delay_us(889);
		else
				RA3 = TRUE;
				__delay_us(889);
				RA3 = FALSE;
				__delay_us(889);
		// Shift remote.bit_mask right 1 bit 0x20->0x10->0x08->0x04->0x02->0x01
	//BUTTON UP
	RA3 = FALSE;
	__delay_us(889);
	RA3 = TRUE;
	__delay_us(889);
	RA3 = FALSE;
	__delay_us(889);
	RA3 = TRUE;
	__delay_us(889);
	// Send a toggle bit - 0
	RA3 = TRUE;
	__delay_us(889);
	RA3 = FALSE;
	__delay_us(889);
		// determine whether to put a 0 or 1 on to the DATA pin
				RA3 = FALSE;
				__delay_us(889);
				RA3 = TRUE;
				__delay_us(889);
		else
				RA3 = TRUE;
				__delay_us(889);
				RA3 = FALSE;
				__delay_us(889);
				RA3 = FALSE;
				__delay_us(889);
				RA3 = TRUE;
				__delay_us(889);
		else
				RA3 = TRUE;
				__delay_us(889);
				RA3 = FALSE;
				__delay_us(889);
  • Free Documents.pdf
Do you made the basic checks:
- everything is power up
- the microcontroller is running
- the microcontroller is setup correctly
- the keypad is reading correctly
- the RA3 is set as output
- on IR LED which is the voltage drop on it? is biased corectly
At a first and quick look over the firmware everything seems to be ok.
An oscilloscope will be helpful for debug or a PICKIT2 as analyzer.
Greetings
Thanks for reply....I had problem to burn pic16f57...Also RA3 out should be modulated at 36-38khz for IR transmission...I modified this code for PIC18 development board and it's working well....!!
Again Thanks..I will post my whole project ltr for others..!!
