Random data signal in cadence
rjshmadala
Junior Member level 2
Hello friends,
I have small doubt.when we simulationg digital gates in cadence.which symobl in cadence should we use for producing a random data(suppose we use Vpulse for pulse signal,what should we use for random data).i used input data as a pulse it is giving results.but for random data what we have to use
Regards
Rjshmadala
You will have to use the VPWL and specify the nunber of pairs of points you want and specify the timing.
hello,
I have used that signal and i did simulations too. actually i need random signal for Clock anda Data recovery circuits there the width of 0 and 1 should be same.i need a siganl like 0001111000111100011. like that in using Vpwl it is difficlut to produce random siganl with some frequency and having same widths isnt'it
regards
rjshmadala
You can do it using VPWL, but the timing information has to be correct for that. A little bit of basic calculation is needed thats all. I have used it to produce random data for my I/O receiver design.
