RAM Debug configuration works, but Flash Debug not (IAR)
kender
Stanford, SF Bay Peninsula, California, Earth, Sol
re: RAM Debug configuration works, but Flash Debug configuration gives error message (IAR Embedded Workbench, LPC2368)
Colleagues,
I have a project that works just fine in RAM Debug configuration with J-Link. I’ve switched to Flash Debug configuration, recompiled successfully. When I initiate the debug session, I get errors:
Fri Dec 04 14:21:08 2009: Error in C:\Program Files\IAR Systems\Embedded Workbench 5.0 Kickstart\ARM\config\flashloader\NXP\FlashNXPLPC512k2.mac at line 13, col 20: Operation error.
Fri Dec 04 14:21:08 2009: Error while calling macro execUserFlashInit
Fri Dec 04 14:21:12 2009: Fatal error: Write memory error @ address 0xE01FC10C, word access: Adaptive clocking timeout.
JTAG Timeout during adaptive clocking: RTCK did not respond.
Could you provide any insight why this is happening and what should I try in order to fix this?
Thanks,
- Nick
bobcat1
Hi
In the debugger setup menu change ADAPTIVE clocking to AUTO
OPTION->JLINK->JTAG SPEED ->AUTO
Also change the linker file to FLASH
All the best
Bobi
The microcontroller specialist
vijay s
Full Member level 3
Coimbatore, India
Hi folks..
can anybody give me an idea how to write interrupt Routine in IAR for ARM... i have used KEIL where start-uo code inits Interrupt vector and its easy to write interrupt function..
please get me an idea or send me some code with interrupts to svijayelex@gmail.com
kender
Hi Bobi,
Changed the JTAG speed to Auto, and I no longer get the JTAG timeout error. But I'm still getting the write memory error:
Sat Dec 05 12:41:59 2009: Fatal error: Write memory error @ address 0xE01FC10C, word access: Memory access timeout.
