zlatkoMM said:I build this radio but with BF 247 and work fine,you can also use BF 256 .
echo47 said:I see several other web sites describing that little receiver. You may find some answers there:
https://www.electronics-lab.com/projects/rf/007/index.html
https://solomonsmusic.net/RadioShackSpecial.html
Kekkaishi said:One more question, the MPF102 FET Transistor is out of stock at my area. So may I know other transistor that could replace this MPF102?
zlatkoMM said:Also you can use BF247 or BF 256 fet .
I not suggest you build coil on board becose how can you adjust cooil if is on board?
So better build with Cu wire 0.8 to 1 mm.
Varicap with 2 plug must be good for FM.
