Radiaition Pattern reconfigurable Antenna at 400 MHz
nvt088
Member level 4
Member level 4
Jupiter
How can I make a microstrip antenna having reconfigurable radiation pattern at 400MHz?
Dielectric constant of substrate is 1.35 (Fabric).
If I use normal technique, size of antenna will be very big.
Many thanks
Many thanks
Dear nvt088,
please explain what is the "reconfigurable radiation pattern", and what antenna options you are interested in - gain, directional characteristics, size, etc ...
and it seems to me that the frequency 400 MHz too low for microstrip technology.
antp
Dear nvt088,
antp
Thank antp,
Reconfigurable radiation pattern means beam-steering. I want to steer antenna's beam by PIN diodes.
Sizes of antennas is limitted by 10x10 cm2 or 15x15 cm2, gain is 2-3 dB.
I want to use microstrip antenna because it's a directional one. Can you suggest me other types of directional antennas?
If we make normal microstrip antenna --> It's too big. Is these any technique to make a small microstrip antenna at 400MHz, for example, spiral microstrip antenna?
Many thanks!
